Nirmal Paudel
COMSOL Employee
8 years ago
09.02.2016, 15:07 GMT-5
Hi Zhi,
In 3D geometry, if you have a closed loop conductor carrying current, and magnetic material around it, then most of the magnetic energy is stored in the magnetic material. However, if you have just a coil in air, the energy will be distributed to some distance away. You would have to make the air volume sufficient large or use the Infinite Element Domains to correctly compute the inductance. In any case, it is important that you integrate the energy over the entire volume (system) to compute the inductance.
You might find this power inductor example helpful:
www.comsol.com/model/modeling-of-a-3d-inductor-10299
However, if the coil is open ended, you will never get the correct inductance value as described here:
www.comsol.com/blogs/computing-the-inductance-of-a-wire/
Additional blog that might be interesting:
www.comsol.com/blogs/model-cables-and-transmission-lines-in-comsol-multiphysics/
Best Regards,
Nirmal
Hi Zhi,
http://www.comsol.com/model/modeling-of-a-3d-inductor-10299
http://www.comsol.com/blogs/computing-the-inductance-of-a-wire/
http://www.comsol.com/blogs/model-cables-and-transmission-lines-in-comsol-multiphysics/
Best Regards,
Nirmal
