Axis formatting
Dear users, greetings.
I would like to know how to produce graphs, where the both x- and y-axis are numerically consistent. For instance, on y-axis I have the following numbers displayed:
0.18, 0.2, 0.22, 0.24, 0.3 and etc.
Instead, I want them all to be consistent as shown here
0.18, 0.20, 0.22, 0.24, 0.30..
How
3 Replies Last Post 02.02.2016, 02:15 GMT-5
Posted: 9 years ago 01.02.2016, 06:12 GMT-5
In 5.1 and 5.2 you can achieve this as follows:
- Expand the Number Format section in the plot group.
- Enable Manual axis settings.
- Check the Show trailing zeros check box.
- Change the Precision so that you get the right number of significant digits. In your example it is 3.
In 5.1 and 5.2 you can achieve this as follows: - Expand the Number Format section in the plot group. - Enable Manual axis settings. - Check the Show trailing zeros check box. - Change the Precision so that you get the right number of significant digits. In your example it is 3.
Posted: 9 years ago 01.02.2016, 20:20 GMT-5
Thank you, Mr Andersson.
Can I format each axis individually though?
[QUOTE] In 5.1 and 5.2 you can achieve this as follows: - Expand the Number Format section in the plot group. - Enable Manual axis settings. - Check the Show trailing zeros check box. - Change the Precision so that you get the right number of significant digits. In your example it is 3. [/QUOTE] Thank you, Mr Andersson. Can I format each axis individually though?
Posted: 9 years ago 02.02.2016, 02:15 GMT-5
No, you can't.
[QUOTE]Thank you, Mr Andersson. Can I format each axis individually though?[/QUOTE] No, you can't.
