What is Enorm in RF module?
Iam confused what is Enorm. Whether it stands for the normal component with respect to to the incident surface?
Can some body help me
thanks
Irfan
3 Replies Last Post 12.10.2010, 08:04 GMT-4
Posted: 1 decade ago 12.10.2010, 02:12 GMT-4
to get better help, try to at least specify version, and better also application mode/physics used.
Then when you have a doubt, try to find the equation for the variable, these can be seen in the equation view in V4 or in the physics Equation settings in 3.5.
In any case searching the doc is rather useful too, index the pdf files it help to find your way as useful info is placed in several docs
Hi to get better help, try to at least specify version, and better also application mode/physics used. Then when you have a doubt, try to find the equation for the variable, these can be seen in the equation view in V4 or in the physics Equation settings in 3.5. In any case searching the doc is rather useful too, index the pdf files it help to find your way as useful info is placed in several docs -- Good luck Ivar
Posted: 1 decade ago 12.10.2010, 06:41 GMT-4
Ivar is right, there isn't much information there. Nevertheless, normE is reserved for the absolute magnitude of E-field. So Enorm is probably something else :)
Posted: 1 decade ago 12.10.2010, 08:04 GMT-4
thanks guys, i am using V4.
