9 years ago
20.01.2016, 12:48 GMT-5
which physics are you using exactly (I do not have the semiconductor module, so I cannot check), what are you dependent variable ? If it's V then Vx = dV/dx and (Vx,Vy,Vz) are the electric potential in [V/m] these are already defined internally in COMSOL.
If you are solving for another variable than V and V is probably derived from the other variables, then it could be that d(V,x) is not defined.
In ES physics, solving for V, plotting both Vx and d(V,x) work OK
Check the doc carefully and check for each physics which are the dependent variable one are really solving for. and take a look "under the hood" by turning on the Equation view in the preferences to see the internal variables of COMSOL
Jeff Hiller
COMSOL Employee
9 years ago
20.01.2016, 14:59 GMT-5
I am assuming that you are using the finite volume formulation in the Semiconductor Module, where shape functions are constant, hence the zero derivatives.
