Hello Amr Abdelghany
28.01.2013, 22:45 GMT-5
I had the same problem. Anyone can help?
29.01.2013, 01:47 GMT-5
from my experience, not much to do as STL is not a "solid" 3D format, if you could use STEP, ACIS or Parasolid or one of the native 3D geometry formats you will have more chances to get the import successful
20.03.2013, 12:19 GMT-4
Hi!
I managed to find a solution. It is not trivial nor free. We can import the .stl file with +CAD (Simpleware), convert it to a mask and then save/export it as a +ScanIP (simpleware) file. Once in +ScanIP we open the file with the mask and we create a NURBS surface from the mask. We can export the mesh in different formats that comsol accepts. I tried with .igs extension and it worked.
I followed a suggestion here
www.comsol.com/press/news/article/117/
www.comsol.com/products/interfaces/simpleware/
Hope it helps someone.
Hi!
http://www.comsol.com/press/news/article/117/
http://www.comsol.com/products/interfaces/simpleware/
20.03.2013, 12:28 GMT-4
I am also face the same problem and that's why i am join this forum today to participate in discussion and find the solution of this problem. Thanks for explain this issue, now i will try to do through this way.
