Cannot save after simulaion - Error = End of File Reached
Hello, I am having trouble saving my simulations when they have finshed. I am getting the error message:
"End of File Reached. - File block size: 59625584"
Also, when I try to plot and/or export the data, some of the time steps seem to be missing. Usually, it is the first time steps as the results from the end of the simulation are still visible.
Any ideas?
2 Replies Last Post 06.07.2018, 09:46 GMT-4
Posted: 7 years ago 05.07.2018, 23:33 GMT-4
Have you tried clearing all the Temp file that Comsol makes ? In the Temp folder. You can save pretty big files, up to 6 Go, but if you do "clear solutions" it reduces it a lot.
For the other problem, does it happen when you increase your steps ? If so, I would check that when you export all the steps are really taken into account. It happens that when I increase a sweep from a simulation to another, and when I export the data, even though I select all the data, I had to manually clicked on the rest to be selected too in the little box below.
François
Hi, Have you tried clearing all the Temp file that Comsol makes ? In the Temp folder. You can save pretty big files, up to 6 Go, but if you do "clear solutions" it reduces it a lot. For the other problem, does it happen when you increase your steps ? If so, I would check that when you export all the steps are really taken into account. It happens that when I increase a sweep from a simulation to another, and when I export the data, even though I select all the data, I had to manually clicked on the rest to be selected too in the little box below. François
Posted: 7 years ago 06.07.2018, 09:46 GMT-4
I need to save the complete solution so clearing the solution doesn't help me. I did however delete all of the temp files so tha the only ones present were for one simulation, and that didn't seem to help.
Manual selection of the data doesn't work. It still cannot expert the missing time values. I can select a subset of time values (usually from the end of the simulation) and export those. However, I get an error message if I try to export the missing time values.
I need to save the complete solution so clearing the solution doesn't help me. I did however delete all of the temp files so tha the only ones present were for one simulation, and that didn't seem to help. Manual selection of the data doesn't work. It still cannot expert the missing time values. I can select a subset of time values (usually from the end of the simulation) and export those. However, I get an error message if I try to export the missing time values.
