van't Hoff and kinetics equation
Posted 28.04.2011, 17:05 GMT-4 0 Replies
I am new to COMSOL . I needed to include a "mass source" in Darcy law model and "heat source" in heat transfer in porous media model.The source term is as follows
Mass source formula: -(1-porosity)*m
where, porosity=0.5, Kinetics Equation: m=Ca*exp(-Ea/(Ru*T))*log(P/Peq)*(rho_ss-rho_s)
rho_ss=3240kg/m^3, rho_s=3200kg/m^3, Ca=100(1/s), Ru=8.314(J/kg.K), Ea=3e5(J/kg).
Heat source formula:
(1-porosity)*dH*m
where, dH=30800 J/mol
Peq is found by van't Hoff equation, Peq=exp(A-B/T) where A and B are material constants, T is domain temperature and P is gas pressure. The problem that i have is
(i) when i try to include "Peq" and "m" formulae in global definitions>variables, i get error message in exp and log functions. when i remove exp and log functions from the respective equations, no error message is displayed. I don't know what to do. Is it because P and T (the unknowns) should be given some arbitrary value initially or should i do something else? Your suggestions will be greatly helpful.Thank you.
Karthick
Hello karthick selvam
