undefined variable error
Dear,
I am using General Form PDE to solve my problem. Although I defined all the initial and boundary conditions, I am having such a problem with my dependent variable, Col
Undefined variable.
- Variable: Col
- Geometry: geom1
- Domain: 1
- Feature: Time-Dependent Solver 1 (sol1/t1)
Can you please help regarding with the problem?
Many thanks,
Kevser
1 Reply Last Post 06.01.2017, 08:59 GMT-5
Posted: 8 years ago 06.01.2017, 08:59 GMT-5
Hi Kevser,
At the risk of stating the obvious, it looks like the variable Col is not defined on domain 1. You may want to check whether the PDE physics interface for which Col is a dependent variable has been properly assigned to domain 1.
Hi Kevser, At the risk of stating the obvious, it looks like the variable Col is not defined on domain 1. You may want to check whether the PDE physics interface for which Col is a dependent variable has been properly assigned to domain 1. Best, Jeff
