Transport of Diluted Species, incorrect concentrations
Posted 14.10.2015, 01:06 GMT-4 Fluid & Heat, Computational Fluid Dynamics (CFD), Microfluidics 0 Replies
I have been trying to do the Comsol Micromixer tutorial which can be found under the following link:
www.comsol.com/model/download/215621/models.mph.micromixer.pdf
I succeeded in replicating all the flow patterns and graphs as in the tutorial.
Now my next step is to replace the existing structure with another structure. It is a tube with diameter .5mm, with a circular path three quarters of a circle of diameter 10mm.
With respect to the tutorial I changed the boundary conditions of the laminar flow. In the initial condition 1 I changed the velocity field to (0,0,0). And at the inlet I changed the velocity to U_mean and Normal inflow velocity. At the laminar flow discretization section I changed to P1+P1.
Now in the results of the simulation of the tube the concentration is not between 0 and 27 mol/m3, as expected and also shown in the results of the tutorial, but between 14 and 27 mol/m3.
Does anybody know what causes the outcome of the concentration profile to be wrong?
Bas
Hello Mr Bas
