Solving enzyme reaction and diffusion
I am trying to solve a reaction diffusion problem. It is time dependent and I am expecting to get at t=0 the concentration of product at point d=0. My initial concentration of product is 0. There is a generation of product Rsp= Vmax as in my system S >>> Km.
I am attaching my problem here. Kindly let me know how this issue can be resolved.
Thanks!
7 Replies Last Post 05.08.2015, 07:01 GMT-4
Posted: 9 years ago 04.08.2015, 05:27 GMT-4
According to what I understood from your problem set-up, I attach here my solution. Note that substrate is initially everywhere at concentration S but is consumed in the reaction. The distances are so small that the entire space is filled with product rather quickly.
BR
Lasse
According to what I understood from your problem set-up, I attach here my solution. Note that substrate is initially everywhere at concentration S but is consumed in the reaction. The distances are so small that the entire space is filled with product rather quickly. BR Lasse
Posted: 9 years ago 04.08.2015, 07:13 GMT-4
Hi Lasse,
I cant open the file, its in later version.
Hi Lasse, I cant open the file, its in later version.
Posted: 9 years ago 04.08.2015, 09:04 GMT-4
Which version do you have?
Posted: 9 years ago 04.08.2015, 10:04 GMT-4
I have COMSOL 4.4
I have COMSOL 4.4
Posted: 9 years ago 04.08.2015, 12:03 GMT-4
I made a report of the model. It is not very clear, if I may say so, but I have two variables c1 (product) and c2 (substrate) which diffuse in the entire domain [0,L]. The reaction takes place in the domain [0,d]. At x = 0 and x = L I have No Flux condition. At point x = d no BC is needed at all, neither another separate Convection and diffusion node. I deactivated convection, so it does not appear at all in the node.
Reaction Rsp = Vmax*c2/(Km + c2); it must be defined as a variable under Component Definitions, not global. I deleted all variables under Global Definitions.
I used time stepping 0,10^{range(-6,0.2,0)} because the reaction rate is at highest in the beginning.
Wish this helps
Lasse
I made a report of the model. It is not very clear, if I may say so, but I have two variables c1 (product) and c2 (substrate) which diffuse in the entire domain [0,L]. The reaction takes place in the domain [0,d]. At x = 0 and x = L I have No Flux condition. At point x = d no BC is needed at all, neither another separate Convection and diffusion node. I deactivated convection, so it does not appear at all in the node. Reaction Rsp = Vmax*c2/(Km + c2); it must be defined as a variable under Component Definitions, not global. I deleted all variables under Global Definitions. I used time stepping 0,10^{range(-6,0.2,0)} because the reaction rate is at highest in the beginning. Wish this helps Lasse
Posted: 9 years ago 05.08.2015, 06:58 GMT-4
I need at x=d there should be a flux(P) and concentration(P) continuity. I don't need a boundary condition for that?
Posted: 9 years ago 05.08.2015, 07:01 GMT-4
No. Comsol assumes continuity of fluxes and concentrations unless you deliberately wish to change it. That could be due to, say, partitioning between the aqueous and organic phases.
