Phase change material inside a Pipe flow
Posted 14.07.2015, 07:05 GMT-4 Fluid & Heat, Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), Heat Transfer Version 4.4 1 Reply
Hi all,
I need to simulate a phase change material inside a pipe flow (liquid -> gas). So, the transformation is isothermal. I would like simulate the cooling of a concrete slab with a heat exchange pipe. The gas in outlet is slightly superheated, so maybe the solution would be to add a phase change material into the Non-Isothermal Pipe Flow module? What kind of physics would you recommend me to use?
Thank you in advance
Yann
Yann
1 Reply Last Post 27.07.2015, 07:21 GMT-4
