Interpolation function in v4
Hi all,
In COMSOL v3.5 I use the following commands to define interpolation functions from matlab. However I could not find a way to do the same thing in v4. Is creating a file (spreadsheet, grid, sectionwise) the only way to do this in v4?
Thanks a lot,
Andre
fcns{1}.type='interp';
fcns{1}.name='rho_design';
fcns{1}.method='linear';
fcns{1}.extmethod='const';
fcns{1}.defvars='true';
cellX = cell(1,m);
for i=1:m
cellX{i} = num2str(x(i));
end
cellY = cell(1,n);
for i=1:n
cellY{i} = num2str(y(i));
end
cellF = cell(1,m*n);
for i=1:m*n
cellF{i} = num2str(F(i));
end
fcns{1}.x = cellX;
fcns{1}.y = cellY;
fcns{1}.data = cellF;
5 Replies Last Post 10.04.2012, 11:08 GMT-4
Hello Andre Teves
Posted: 1 decade ago 31.10.2011, 17:10 GMT-4
hello
did you resolve the problem?
I've the same difficulties
thx
hello did you resolve the problem? I've the same difficulties thx
Posted: 1 decade ago 31.10.2011, 20:56 GMT-4
Just use the built-in function generator of v4+. You can define an equation or read from an external file. No need for MATLAB unless you just want to use it.
Posted: 1 decade ago 17.02.2012, 03:42 GMT-5
Hi all,
Thanks a lot,
Andre
cellX = cell(1,m);
for i=1:m
end
cellY = cell(1,n);
for i=1:n
end
for i=1:m*n
end
fcns{1}.x = cellX;
fcns{1}.y = cellY;
Hello Andre,
Were you able to find a solution that did not imply reading the data from a text file?
Armando
[QUOTE] Hi all, In COMSOL v3.5 I use the following commands to define interpolation functions from matlab. However I could not find a way to do the same thing in v4. Is creating a file (spreadsheet, grid, sectionwise) the only way to do this in v4? Thanks a lot, Andre ----- fcns{1}.type='interp'; fcns{1}.name='rho_design'; fcns{1}.method='linear'; fcns{1}.extmethod='const'; fcns{1}.defvars='true'; cellX = cell(1,m); for i=1:m cellX{i} = num2str(x(i)); end cellY = cell(1,n); for i=1:n cellY{i} = num2str(y(i)); end cellF = cell(1,m*n); for i=1:m*n cellF{i} = num2str(F(i)); end fcns{1}.x = cellX; fcns{1}.y = cellY; fcns{1}.data = cellF; [/QUOTE] Hello Andre, Were you able to find a solution that did not imply reading the data from a text file? Regards, Armando
Posted: 1 decade ago 17.02.2012, 16:18 GMT-5
No, I'm still using a text file to comunicate with COMSOL. But that works fine for me!
Posted: 1 decade ago 10.04.2012, 11:08 GMT-4
In 4.2a there is a Interpolation, maybe it works for you.
Model>Definitions>Functions>Interpolation
In 4.2a there is a Interpolation, maybe it works for you. Model>Definitions>Functions>Interpolation
