Post-Processing: 2D Contour Plot
Greetings All!
I am creating a 2D contour plot to lay over the top of a surface plot. The contour plot I have created has white contour lines over the top of the colored (gradient) surface plot. This works fine, but I have not found a way to modify the weight of the contour lines - I would like to make them thicker so they stand out a little more. I thought that I would be able to figure this out quickly, but I can't seem to find the right place in 4.0a.
Anyone know about a possible fix? Thanks!
3 Replies Last Post 19.04.2012, 11:21 GMT-4
Hello Mark Suchomel
Posted: 1 decade ago 21.11.2011, 16:07 GMT-5
Hi, did you find a solution? I'm trying to do the same thing!
David
Hi, did you find a solution? I'm trying to do the same thing! Thanks, David
Posted: 1 decade ago 22.11.2011, 11:40 GMT-5
No such luck, but I haven't looked at it at all recently. I have since updated to v4.2 which may (or may not) have fixed the problem. If I come across a solution I will pass it along.
Mark
No such luck, but I haven't looked at it at all recently. I have since updated to v4.2 which may (or may not) have fixed the problem. If I come across a solution I will pass it along. Mark
Posted: 1 decade ago 19.04.2012, 11:21 GMT-4
did anyone find a solution yet?
Elmar
Hi, did anyone find a solution yet? Elmar
