Bug in Application Builder ?
Logic bug application builder?
With the code:
for(int i = 0;i<2;i+=1){
model.param().set("q1",30+10*i);
model.param().set("q2",10+5*i);
model.geom("geom1").run();
model.mesh("mesh1").run();
model.study("std1").run();
model.result().report("rpt1").set("filename","Z:\\Comsol 51\\Study2-"+i+".docx");
model.result().report("rpt1").run();
it should runs like this:
(like java, it runs from the first code at the top to the last code at the end, a code will be started only after all code in front of it finished.)
set X=0.04—geometry build(for X=0.04)—mesh—compute study2(for X=0.04)—report(with name Study2-0, for X=0.04)
set X=0.05—geometry build(for X=0.05)—mesh—compute study2(for X=0.05)—report(with name Study2-1, for X=0.05)
But after testing it runs like this:
set X=0.05—geometry build(for X=0.05)—mesh—compute study2(for X=0.05)—report(with name Study2-0, for X=0.05)—report(with name Study2-1, for X=0.05)
i don't know why,is there any problem with my code or is it a bug in application builder?
0 Replies Last Post 15.06.2015, 08:11 GMT-4
Hello Yuchen Cui
