can not generate mesh
Hi, I have drawn the geometry of a DC motor, but when I generate mesh, it always popup such error: Error: 4100, failed to generate mesh for subdomain. -subdomain 70 internal error in advancing front mesher.
this error happens in the airgap area and I have no idea how this happen. I drew this same geometry before, but with smaller size, say the radius is 1/2 of this one, there is no problem with that. could somebody help me analyze the reason for this?
3 Replies Last Post 29.03.2011, 15:33 GMT-4
Posted: 1 decade ago 19.08.2010, 23:18 GMT-4
I'll take a guess. When a problem includes regions that are both large and small (detailed), the default mesh settings are sometimes inadequate to handle it. I recommend you set up some interior boundaries (without boundary conditions, which should default to continuous conditions) and then define the fineness of the mesh independently in the small and large regions. Alternatively, once you have divided it up as I said, you can mesh the problem on a per-domain basis, in which case you may find it advantageous to mesh the finer domains *before* you mesh the coarser adjoining ones. That makes it easier for the meshing routine to figure out where to insert mesh points.
Posted: 1 decade ago 29.03.2011, 04:55 GMT-4
Hi Robert,
I also have the same with meshing of the airgap in an induction machine. Can you explain this solution more clearly?
Thank you
Hi Robert, I also have the same with meshing of the airgap in an induction machine. Can you explain this solution more clearly? Thank you
Posted: 1 decade ago 29.03.2011, 15:33 GMT-4
I have noticed often issues when a geometry contains multiple loops, in these cases its often useful to add some interiour boundaries, and mesh "by parts/sections" manually
Hi I have noticed often issues when a geometry contains multiple loops, in these cases its often useful to add some interiour boundaries, and mesh "by parts/sections" manually -- Good luck Ivar
