Substracting a coil from a pipe
I am building a barrel to wind a wire on to.
The helix i defined with the primitive geometry
The barrel wire is mounted on, i have swept a square work plane along a parametric equation, of the helix.
To make the barrel i just then defined two cylinders,
thought i could just use use a boolean operator to subtract the square cross section helix.
Please find attached,
Many thanks
2 Replies Last Post 27.05.2015, 04:40 GMT-4
Posted: 9 years ago 26.05.2015, 17:05 GMT-4
Francis,
this issue is indeed a bit strange. I was curious and played a little. This is what I did:
- In the workplane and in the Parametric Curve: Make the helix a little bigger, r = 1.01, to avoid the lateral edges touching the cylinder surface
- In the Sweep in Advanced Settings: Change Geometry reprentation from Spline to Bezier.
This all should not be required in my opinion. It should work as you had set it up. Might be a question to the support.
I am attaching my modifications.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Francis, this issue is indeed a bit strange. I was curious and played a little. This is what I did: - In the workplane and in the Parametric Curve: Make the helix a little bigger, r = 1.01, to avoid the lateral edges touching the cylinder surface - In the Sweep in Advanced Settings: Change Geometry reprentation from Spline to Bezier. This all should not be required in my opinion. It should work as you had set it up. Might be a question to the support. I am attaching my modifications. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 9 years ago 27.05.2015, 04:40 GMT-4
Edgar,
That seems to have done the trick,
yeah I should utilise technical support,
thanks again
Edgar, That seems to have done the trick, yeah I should utilise technical support, thanks again
