Quick build of all meshes in Parameter Sweep?
COMSOL'ers:
Is there a way to quickly build all the meshes over a parameter sweep, without running through the computational steps in the study?
At a certain parametrized geometry, I am getting a failure. I know how to refine the mesh to fix it, but I do not know if these changes will then affect all the other parametrized models. Also, being able to test the mesh for all parameters will allow me to quickly optimize for minimal mesh size (pending solution convergence).
Thanks!
-Ado
3 Replies Last Post 14.05.2015, 17:25 GMT-4
Posted: 10 years ago 14.05.2015, 13:57 GMT-4
Hello Bryan,
Sure, you can just disable any and all physics branches in your model. See attached toy example.
Hello Bryan, Sure, you can just disable any and all physics branches in your model. See attached toy example. Jeff
Posted: 10 years ago 14.05.2015, 17:12 GMT-4
Thank you, Jeff--nice that there is an easy solution.
I could not load your example--I am at 5.0, and it seems your file is 5.1 (states it was created with a later version). Nevertheless, with your advice, I was able to successfully run a sweep and survey each mesh, so I would consider that a success!
-Ado
Thank you, Jeff--nice that there is an easy solution. I could not load your example--I am at 5.0, and it seems your file is 5.1 (states it was created with a later version). Nevertheless, with your advice, I was able to successfully run a sweep and survey each mesh, so I would consider that a success! -Ado
Posted: 10 years ago 14.05.2015, 17:25 GMT-4
Yes, it works the same in 5.0 and 5.1.
With that said, if it's up to you, upgrade to 5.1; it's got lots of new goodies (see www.comsol.com/release/5.1).
Yes, it works the same in 5.0 and 5.1. With that said, if it's up to you, upgrade to 5.1; it's got lots of new goodies (see http://www.comsol.com/release/5.1). Jeff
