10 years ago
10.05.2015, 15:52 GMT-4
for me the main issue is that you have selected Geometry "assembly" mode, this means that all your domains are independent.
To check such a model, I would have started by applying a body load => gravity and use a time dependent solver just to check that the body remains "up" as expected, you will be surprised by the result if you try this in assembly mode :)
Then you two "contact pairs" are of no use because you need continuity to hold the shoulders in place. or at least a pair BC constraint must be manually defined.
The best would be to start with 2-3 bodies and you test out the Geometry "assembly" and "union" mode to be sure you understand these: have the 3 bodies intersect (i.e. cubes somewhat overlapping each other). Then fix one boundary and apply a gravity body load and do a stationary study (turn on the plot while solving for each solver steps to monitor better what is happening ...)
