Reading simulation results through VBA code in excel
I am trying to extract the results of a COMSOL optimization through VBA code in Excel with no luck. To my knowledge the simulation runs but i can't access the results. I am new both to VBA and Livelink but I expected the procedure to be straight forward which unfortunately it is not. I want to read the optimized parameter as well as a few other probe values that are in the component definitions and are evaluated in the study, back into Excel. The relevant VBA code is this:
'Get data from Excel cells
Iact = Sheets("Data_acc.geom").Range("B" & ActiveCell.Row).Value / 1000
Disp = Sheets("Data_acc.geom").Range("F" & ActiveCell.Row).Value / 1000000000
'Set data to COMSOL parameters and run the optimization study
Call model.param.set("Iact", Str(Iact))
Call model.param.set("Disp_target", Str(Disp))
Call modelutil.ShowProgress(True)
Call model.get_study("std7").Run
'Extract results <- problem here
Set res_CTE = model.result().numerical().Create("res_CTE", "Global")
Call res_CTE.set("expr", "CTE_3CSIC")
Call res_CTE.set("data", "dset1")
results_CTE=res_CTE.getData(0) <- this line doesnt work
CTE_3CSIC is the optimized parameter. I have looked up the LiveLink For Excel Users Guide as well as the COMSOL API reference but couldnt find the proper way to do this. Any help is greatly appreciated.
0 Replies Last Post 04.05.2015, 08:00 GMT-4
Hello Sotiris Thomas
