Teflon Die Extrusion
Posted 03.04.2015, 11:32 GMT-4 Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), Mesh, Modeling Tools & Definitions, Parameters, Variables, & Functions, Results & Visualization, Studies & Solvers Version 4.4 1 Reply
This simulation is modeling a 25% glass filled-teflon billet extrusion through a steel die (1/4 of the entire model). I added a stationary study with laminar conjugate heat transfer with solid mechanics and applied symmetry. The exterior extrusion should have thermal expansion.
I am not sure where the error is, but it can be the actual material properties, boundary assignments, or the mesh. I am trying to plot surface pressure, temperature, velocity and von mises.
This is the error message I get.
Segregated group 1
Out of memory during assembly.
Thank you
