Automatic remeshing with deformed geometry/moving mesh singularity
I am trying to model a sphere that changes phase from the outer radius moving inwards, but I'm having some difficulties. Using deformed geometry I can simulate it up to a certain time, however after that the mesh deformation becomes too large, causing the simulation to stop converging.
1. Should I use deformed geometry or moving mesh for this?
2. I tried using automatic remeshing but regardless of the condition I use, it instantly reaches a singularity after remeshing:
The following feature has encountered a problem:
Repeated error test failures. May have reached a singularity.
Time : 0.5516356412745114
- Feature: Automatic Remeshing 1 (sol1/t1/ar1)
How can I stop it reaching a singularity?
I added a picture showing what the mesh looks like after remeshing, which seems fine, so I'm not sure why it reaches a singularity. I already tried varying the time steps and mesh sizes, with same results.
1 Reply Last Post 25.02.2016, 22:18 GMT-5
Hello Sebastiaan Klaasse
Posted: 8 years ago 25.02.2016, 22:18 GMT-5
Have you find answer for your question?
I also have a same problem!
Do you have other approach?
Thanks in advance.
Zhang Wei
Hi, Have you find answer for your question? I also have a same problem! Do you have other approach? Thanks in advance. Best regards, Zhang Wei
