Square wave or rectangle function input voltage
Hello fellow COMSOLers,
I am trying to model an electrical pulse going through a metal trace (similar to the classic beginner's tutorial showing Joule heating of an aluminum film on a silicon substrate). The pulse will be a repeating rectangle function -- the voltage will be turned on and off repeatedly to create fatigue stress in the trace.
I am currently using version 4.0, but also have a license for 3.4. In 4.0, I found that you can define rectangle functions by right clicking on "Global Definitions". (This was described in the 4.0 introductory workshop). However, I'm not sure how to actually use the function once I've defined it.
Does anyone know of a way that I could do this, in either 4.0 or an earlier version? I also have MATLAB, and would be interested in learning how to script this if there's no way to do it through the COMSOL GUI.
Thanks!
-Anna
1 Reply Last Post 25.06.2010, 09:37 GMT-4
Posted: 1 decade ago 25.06.2010, 09:37 GMT-4
the easiest is to define the "rectangle" pulse in V4 as this implements the Heaviside functions to smoothen the turn on and off (plot the figure (click on the icon) to check the shape and the order of varibles, and check the doc for the variables and operators p 170 MPH_UG.PDF) Its easier than in the earler versions. The turn on and off time is by default 0.1, see the "smooting tab". then you call it with simply "rect1(t-Dt)" where Dt is the time to the middle of the pulse. To make it periodical use a modulo call on t "mod(t-Dt,DDt)" see p179 where DDt is the full period
As the function modulates from 0 to 1 without units you must multiply it by some amplitude depending where you use it
have fun Comsoling
Hi the easiest is to define the "rectangle" pulse in V4 as this implements the Heaviside functions to smoothen the turn on and off (plot the figure (click on the icon) to check the shape and the order of varibles, and check the doc for the variables and operators p 170 MPH_UG.PDF) Its easier than in the earler versions. The turn on and off time is by default 0.1, see the "smooting tab". then you call it with simply "rect1(t-Dt)" where Dt is the time to the middle of the pulse. To make it periodical use a modulo call on t "mod(t-Dt,DDt)" see p179 where DDt is the full period As the function modulates from 0 to 1 without units you must multiply it by some amplitude depending where you use it have fun Comsoling Ivar
