Selecting Similar Objects
Hii,
I have a model where I have say 2000 objects. 500 of them are circles with a certain diameter. I want to select all of them (and then extrude it) . Is there any way to do the selection automatically instead of manually clicking on each and every circle ?
2 Replies Last Post 01.04.2015, 07:05 GMT-4
Sven Friedel COMSOL Employee
Posted: 10 years ago 01.04.2015, 03:35 GMT-4
Hi Anup,
you can use in general the selection feature. If your circles have been created by an array operation, you can right there use "create selections" otherwise you can use manually under Component> Definitions an operation like "ball selection" or "box selection" defining a range of coordinates to include objects you want to group.
Sven
Hi Anup, you can use in general the selection feature. If your circles have been created by an array operation, you can right there use "create selections" otherwise you can use manually under Component> Definitions an operation like "ball selection" or "box selection" defining a range of coordinates to include objects you want to group. Best regards, Sven
Posted: 10 years ago 01.04.2015, 07:05 GMT-4
Dear Sven,
Thank you for the reply. :) I did something similar and my work was done.
Dear Sven, Thank you for the reply. :) I did something similar and my work was done.
