Luke Gritter
Certified Consultant
10 years ago
24.03.2015, 14:37 GMT-4
Zaid,
Instead of coupling several physics interfaces together, you should use the either the DC Discharge or the Capacitively Coupled Plasma physics interface. These interfaces contain the functionality of the Drift Diffusion, Heavy Species Transport, and Electrostatics physics interfaces already coupled together.
As you mentioned, the body force is simply the space charge density (dc.scharge in the DC Discharge interface) times the electric field. To apply this body force to the momentum equations in a fluid flow, you need to add a Volume Force to the fluid flow interface (e.g. the Single Phase Flow interface) and enter the components of the body force (dc.scharge*dc.Ex, etc.). These same body force components can be entered as expressions on an Arrow Surface plot to display the force vectors.
Luke Gritter
AltaSim Technologies
Zaid,
Luke Gritter
10 years ago
24.03.2015, 14:51 GMT-4
Thank you for the guidance Mr Gritter. Sir, actually i have to make use of only AC voltage, thus including the electric current and electric circuit interfaces. A reason being that later i will also use my model to optimize the performance of my DBD Plasma actuator by varying the applied AC waveforms and seeing which one is the best. For example, studies in the past have shown that a square waveform outperforms the sine waveform in discharge in terms of induced velocity (due to body force).
Thus my study is to be strictly focused on AC-DBD's (please see my model attached in previous message). Also there are differences in operating conditions and discharge characteristics of a DC-Discharge and CCP versus AC_DBD. My study is focused for aerospace applications of plasma actuators at atmospheric pressure. One reason of preferring AC-DBD over DC discharge is that the breakdown electric field for for AC-DBD is much less than for DC-DBD. This is preferred for aerospace applications.
Could you please suggest me how to approach this problem further in Comsol. I really appreciate the help.
Thank you Mr Gritter
Best regards
Zaid
Best regards
Zaid
Luke Gritter
10 years ago
24.03.2015, 15:00 GMT-4
Zaid,
Despite the name, the DC Discharge physics interface can be used for DBD plasmas with any waveform. Depending on the type of circuit you want to couple to the electrode, you may need to also use the Electric Circuits interface.
Luke Gritter
Zaid,
Luke Gritter
9 years ago
24.05.2015, 12:00 GMT-4
Zaid,
Luke Gritter
Luke , Hi ;
Can i use the DC discharge to model a SF6 electric arc ? if no , which plasma model you recommend ?
Regards ;
[QUOTE]
Zaid,
Luke Gritter
[/QUOTE]
Luke , Hi ;
Regards ;
