Three Electrodes:Is it possible to measure voltage, admittance, or impedance at each individually
Hi all, I'm having some trouble figuring out how to extract the information I would like from my simulation and hoping someone here would be able to help...
My simulation: I've got three electrodes which are being used to sense changes in media as insulating bodies pass above the electrodes.
The 3 electrode layout is: a port electrode, with forced voltage is centered. On either side of the port, there is a ground electrode.
My hope: I would like to compare the voltages, admittances, impedance, at each of the ground electrodes individually.
Is this possible within COMSOL?
Thanks for any help!
-Eric
1 Reply Last Post 23.06.2011, 17:16 GMT-4
Hello Eric Salm
Posted: 1 decade ago 23.06.2011, 17:16 GMT-4
Hi Eric,
I am working on a similar problem as you with 4 electrodes. I am applying current on the outer 2 and want to measure the voltage between the inner 2 electrodes. I am using comsol 3.5a and seeking your help as you have worked on the similar issue.
Kirthika.
-Eric
Hi Eric, I am working on a similar problem as you with 4 electrodes. I am applying current on the outer 2 and want to measure the voltage between the inner 2 electrodes. I am using comsol 3.5a and seeking your help as you have worked on the similar issue. Thanks, Kirthika. [QUOTE] Hi all, I'm having some trouble figuring out how to extract the information I would like from my simulation and hoping someone here would be able to help... My simulation: I've got three electrodes which are being used to sense changes in media as insulating bodies pass above the electrodes. The 3 electrode layout is: a port electrode, with forced voltage is centered. On either side of the port, there is a ground electrode. My hope: I would like to compare the voltages, admittances, impedance, at each of the ground electrodes individually. Is this possible within COMSOL? Thanks for any help! -Eric [/QUOTE]
