20.10.2014, 03:03 GMT-4
When you say that it does not work - what do you mean?
If you could upload your model, or a simplified version of what you are working with it would be much easier to help.
BR Simon
BR Simon
20.10.2014, 03:34 GMT-4
In my COMSOL model ,I have two geometry related parameters. I want to sweep them together. The fisrt parameter has 45 numbers and the second has 60 numbers.But I found that COMSOL would not work for geometry related parameter sweep.
How can I solve this problem.
I have swept geometry without any problems. In your case the issue is the large number of parameters. The solution data woud not fit to anywhere. I have used only 12 values in a rather simple geometry, and that file was already a big one.
Lasse
[QUOTE]
[/QUOTE]
Lasse
