Influence of SF6 gas pressure on Electric field
Hello!
I am trying to simulate the effect of having SF6 gas at 5 bar pressure in a chamber. However, I do not see any effect of gas pressure on electric field i.e., whether SF6 gas is present at 5 bar pressure or at 1 atm, irrespectively I am getting the same electric field values. I intend to optimise this chamber and reduce its dimensions by understanding the influence pressurised SF6 gas will have on the electric field.
How do I make COMSOL understand that my gas (fluid) is at 5 bar pressure and so the computation should show me different values of Electric fields for different gas pressure??
Many thanks!
Kind regards
Tanumay Karmokar
3 Replies Last Post 02.07.2015, 02:44 GMT-4
Posted: 1 decade ago 16.09.2014, 09:37 GMT-4
You would only expect an effect if the electromagnetic properties of the gas change as a function of pressure. If this is not described in the material properties or explicitly in the model, then indeed you will see no effect.
Posted: 1 decade ago 16.09.2014, 11:22 GMT-4
Even if the dielectric properties changed with pressure you wouldn't see an effect if you keep the electrodes at constant potential.
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Even if the dielectric properties changed with pressure you wouldn't see an effect if you keep the electrodes at constant potential. -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 9 years ago 02.07.2015, 02:44 GMT-4
Hello!
I think you already solve the problem, since now we are in July 2015 and your post is on September 2014.
May i know how you overcome the problem since, i'm facing it right now. Any suggestion? Or advice for me?
Hello! I think you already solve the problem, since now we are in July 2015 and your post is on September 2014. May i know how you overcome the problem since, i'm facing it right now. Any suggestion? Or advice for me?
