Issues building a simple 3-D geometry with COMSOL Kernel
I am building a single foam unit cell, you can see the attached file, and am having an issue where a surface is not being deleted after differencing several geometries. When I use the CAD Import Module Kernel, there is no problem, but we have only one license for it and it is sometimes tied up. Since I am building the geometry natively I don't believe I should have to even use it anyway.
Does anyone have an explanation on why it is doing this, or better yet point out something I am doing wrong.
Mario
2 Replies Last Post 09.09.2014, 16:03 GMT-4
Posted: 1 decade ago 09.09.2014, 15:28 GMT-4
Hello Rebecca,
In your "Sphere" node, enter a 45 degrees rotation angle. It will work.
Hello Rebecca, In your "Sphere" node, enter a 45 degrees rotation angle. It will work. Jeff
Posted: 1 decade ago 09.09.2014, 16:03 GMT-4
Got it!
thank you
Got it! thank you
