COMSOL: Dynamic Modeling
I'm interested in simulating a dynamic model, which moves rotationally and translationally. Can COMSOL execute dynamic operations like this and if so what type of software package would I need?
2 Replies Last Post 22.08.2014, 13:19 GMT-4
Posted: 10 years ago 31.07.2014, 17:01 GMT-4
Have you looked in to the Multibody Dynamics Module? If I understand your post correctly, it may be just what you're looking for. See www.comsol.com/multibody-dynamics-module
Have you looked in to the Multibody Dynamics Module? If I understand your post correctly, it may be just what you're looking for. See http://www.comsol.com/multibody-dynamics-module Jeff
Posted: 10 years ago 22.08.2014, 13:19 GMT-4
Jeff,
One of my lab mates was concerned that the model wouldn't be able to execute a single body problem. This is an explicit explanation of the model so you can better answer my question. My model is a pulley with a chord wrapped around it. At each end of the chord it's attached to the center of a rectangular cross section. Each rectangular cross section is attached to a another chord at the ends in the opposite direction to the chord wrapping around the pulley (similar to a seesaw mechanism). The pulley needs to be able to move translationally (bulk movement of the model) , the chord around the pulley needs to move rotationally, and the seesaw mechanisms need to move rotationally. Would the package still be able to execute the model?
Bruce
Jeff, One of my lab mates was concerned that the model wouldn't be able to execute a single body problem. This is an explicit explanation of the model so you can better answer my question. My model is a pulley with a chord wrapped around it. At each end of the chord it's attached to the center of a rectangular cross section. Each rectangular cross section is attached to a another chord at the ends in the opposite direction to the chord wrapping around the pulley (similar to a seesaw mechanism). The pulley needs to be able to move translationally (bulk movement of the model) , the chord around the pulley needs to move rotationally, and the seesaw mechanisms need to move rotationally. Would the package still be able to execute the model? Thanks, Bruce
