10 years ago
29.07.2014, 02:46 GMT-4
Yes, make the thermal conductivity user defined and put for the value of the thermal conductivity some formula in which you use 'T' (probably) for the temperature. Or you can put your formula in the material property of the relevant material.
10 years ago
29.07.2014, 15:26 GMT-4
thank you for the reply.
The actual problem is that if its possible to simulate thermal conductivity change with temperature change.!
I am running a Joule heating simulation to see temperature distribution on a boundary(Aluminum material) using 'step' input/function for a specific time period. I obtain the temperature results for every time steps.
Next, I want to run a case wherein Thermal conductivity of Aluminum changes with temperature change at every time step.
Can it be done??
Can it be done??
Josh Thomas
Certified Consultant
10 years ago
29.07.2014, 15:52 GMT-4
Yes. You can specify temperature dependent material properties. In your case, simply make your thermal conductivity a function of the temperature variable, T.
Josh Thomas
AltaSim Technologies
Josh Thomas
10 years ago
29.07.2014, 16:51 GMT-4
Thank you for the quick reply.
