Post Processing Time Dependent Data
Hi all
I am working on a time dependent study, how can I subtract my data at two different time steps
over my domain and plot it in comsol ?
for instance plotting the
concentration (t=1) - concentration (t=0) over domain ?
Regards
AM
3 Replies Last Post 11.06.2014, 12:53 GMT-4
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 11.06.2014, 08:24 GMT-4
Use a Join data set with the time-dependent solution data set as both Data 1 and Data 2, picking time = 1 for Data 1 and time = 0 for Data 2, for example. Use the default combination method, Difference, to create a data set that is the solution data (t =1) - solution data (t = 0). Then use the Join data set in the plot group where you plot the concentration.
Magnus Ringh, COMSOL
Hi, Use a Join data set with the time-dependent solution data set as both Data 1 and Data 2, picking time = 1 for Data 1 and time = 0 for Data 2, for example. Use the default combination method, Difference, to create a data set that is the solution data (t =1) - solution data (t = 0). Then use the Join data set in the plot group where you plot the concentration. Best regards, Magnus Ringh, COMSOL
Posted: 1 decade ago 11.06.2014, 08:54 GMT-4
You can also use the at() operator, such as plotting
c-at(0,c)
for a concentration c, with the time in the Plot Group set to 1 s, for example.
Hi, You can also use the at() operator, such as plotting c-at(0,c) for a concentration c, with the time in the Plot Group set to 1 s, for example. Best regards, Magnus Ringh, COMSOL
Posted: 1 decade ago 11.06.2014, 12:53 GMT-4
Thank you very much Magnus! Can you please also comment on below
www.comsol.com/community/forums/general/thread/45045/
Thank you very much Magnus! Can you please also comment on below http://www.comsol.com/community/forums/general/thread/45045/
