Parameter value list (elastoplasticity)
Posted 05.05.2014, 04:56 GMT-4 3 Replies
Hello everyone,
I'm simulating a tensile test on a steel tube presenting some defaults with external strain-stress data. I want ultimately to have a strain-stress curve plotted by Comsol for the defective geometry I defined. For that, I defined an interpolation function, named delta, with different numerical values refering to the displacement applied on the top surface of the tube. I also defined a parameter named para, and putted on the prescribed displacement 'delta(para)'. I simply followed the steps of the 'Compression of an Elastoplastic Pipe' model given in Comsol file.
Now in Study 1 --> Step 1 : Stationary-->Study extensions-->Continuation, the model proposes to add the parameter para in the 'Continuation parameter' column and the following : " range(0,0.02,1) range(1.005,
0.005, 1.05) 1.1 2" in the 'Parameter value list' column.
I don't understand the three ranges, nor how Comsol understand the syntax used. Could somebody explain this to me (knowing that what I want ultimately is a strain-stress curve) ? Thanks in advance !
Kind regards.
Kind regards.
3 Replies Last Post 05.05.2014, 10:49 GMT-4
