Hello Dong Liu
23.05.2014, 07:41 GMT-4
I've got the same problem, have you found a solution yet?
23.05.2014, 09:06 GMT-4
I'm using COMSOL4.4 and Matlab 2007b by the way, maybe there's aproblem with the version?
29.07.2014, 11:17 GMT-4
Same problem here. Have you found a solution?
I tried it with comsol 4.4, both version 195 and 248 and tried it with Matlab 2012b and 2014a, and, it doesn't work on multiple PCs. The shortcut Comsol 4.4 with matlab does function properly, but I cannot use that on our remote machine. Also Comsol 4.3b connects without any problem using mphstart.
The comsol server console doesn't show any evidence of a connection being attempted. But the port is open according to "netstat -a".
No luck yet.
No luck yet.
31.07.2014, 02:15 GMT-4
No, I did not find a solution. In the end, I just decided not to use the Matlab connection. I suspected it was because of my MATLAB version, someone else started it with a newer version an another PC and it worked. So I'm sorry I can't be of help.
11.02.2015, 08:26 GMT-5
Any solutions ? Same problem here.
10 years ago
20.04.2015, 09:37 GMT-4
Did u solve the problem? Exactly the same problem here. It is the third time it happens. I reinstalled it twice before, but it was really not an efficient way.
9 years ago
25.08.2015, 16:05 GMT-4
Any chance that an expert answers this trend? I'm getting the same message on my Matlab CmdWin:
Error using mphstart (line 152)
A connection to Comsol could not be established. Please check that a Comsol Server is started prior to calling mphstart
even if the server has been previously started...
Lars Gregersen
COMSOL Employee
9 years ago
08.09.2015, 03:24 GMT-4
There are a number of reasons why using mphstart may fail.
The most common problem is the use of a firewall that prevent the connections. You should also use a recent version of Matlab. The currently supported versions are listed here:
www.comsol.com/system-requirements/module
You can use older versions than the recommended, but some functionality may not work. Matlab versions older than R2010a are known NOT to work.
If you have problems with mphstart then send a mail to support. Please write what operating system you are using and what version of Matlab you have.
Lars Gregersen
Comsol Denmark
http://www.comsol.com/system-requirements/module
Lars Gregersen
Comsol Denmark
9 years ago
19.09.2015, 12:27 GMT-4
Hi I have met the same problem and finally found a solution..
If your condition is the same as me then it must be all fine when you call mphstart for the first time.
The problem happens when the first run is terminated and you want to call mphstart to connect again.
The reason of termination could be that you run ModelUtil.disconnect, or the comsolmphserver is for some reason terminated unexpectedly.
For both condition, before you call mphstart, you should call ModelUtil.clear and got a java exception. Then everything goes well.
I don't know why but it does work. It seems the first run has left something under the ModelUtil object which can inhibit your second connection.
9 years ago
19.11.2015, 10:47 GMT-5
ModelUtil.clear not working for me:
>> import com.comsol.model.*
>> import com.comsol.model.util.*
>> ModelUtil.clear
Undefined variable "ModelUtil" or function "ModelUtil.clear".
>>mphstart
or even
>> ModelUtil.clear
>>mphstart
[QUOTE]
[/QUOTE]
>> ModelUtil.clear
>>mphstart
or even
>> ModelUtil.clear
>>mphstart
