"Java exception" problem during multiple iterations in Livelink for MATLAB
Hi everyone, this forum is great and it helped a lot to grow in COMSOL world.
Anyway, now i am trying to calculate/simulate a phase growth process considering the mass transfer through the interfaces, in which I am using "Livelink for MATLAB' module.
For each iteration, the solution from the previous study was passed down as intial values for the current step and some boundary conditions were changed also. The original plans are to repeat about 10000 iterations, while MATLAB always jumped out after about 2600 iterations with this red "Java exception" warnings. I tried to change the settings in COMSOL and MATLAB wherever shows "cache size" or "buffer size" but it is still happening at exact the same point.
So could you guys help me out with it? Really appreicate your effort and help!!!
ps: I paste the MATLAB warning here. If you want to see the M file, i would upload it later.
Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: The following feature has encountered a problem
(rethrown as com.comsol.util.exceptions.FlException)
The following feature has encountered a problem:
Error in multiphysics compilation.
- Feature: Compile Equations: Time Dependent (sol5158/st1)
Stack trace:
at com.comsol.clientapi.engine.c.handleException(Unknown Source)
at com.comsol.client.interfaces.f$d.f(Unknown Source)
at com.comsol.client.interfaces.f.a(Unknown Source)
at com.comsol.client.interfaces.f.runAndWait(Unknown Source)
at com.comsol.clientapi.engine.APIEngine.runMethod(Unknown Source)
at com.comsol.clientapi.impl.SolverSequenceClient.runAll(Unknown Source)
Caused by: Exception:
at com.comsol.client.interfaces.f.processCommandAnswer(Unknown Source)
... 6 more
at com.comsol.solver.SolverOperation.addError(Unknown Source)
at com.comsol.solver.SolverOperation.execute(Unknown Source)
at com.comsol.model.internal.impl.SolverSequenceImpl.a(Unknown Source)
at com.comsol.model.internal.impl.SolverSequenceImpl.i(Unknown Source)
at com.comsol.model.internal.impl.SolverSequenceImpl$23.a(Unknown Source)
at com.comsol.model.internal.impl.SolverSequenceImpl$23.execute(Unknown Source)
at com.comsol.model.clientserver.ClientManager$1.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
1 Reply Last Post 04.06.2014, 11:11 GMT-4
Hello Jixiao Liu
Posted: 1 decade ago 04.06.2014, 11:11 GMT-4
Have you solved the problem? I am in RF module, and my link also dies during the multiple iterations. Basically, I share the same part of your error message:
Stack trace:
Would be great if you already solved this and shared your solution. Thanks in advance!
Alvin
Have you solved the problem? I am in RF module, and my link also dies during the multiple iterations. Basically, I share the same part of your error message: Stack trace: at com.comsol.clientapi.engine.c.handleException(Unknown Source) at com.comsol.client.interfaces.f$d.f(Unknown Source) at com.comsol.client.interfaces.f.a(Unknown Source) at com.comsol.client.interfaces.f.runAndWait(Unknown Source) at com.comsol.clientapi.engine.APIEngine.runMethod(Unknown Source) at com.comsol.clientapi.engine.APIEngine.runMethod(Unknown Source) at com.comsol.clientapi.impl.SolverSequenceClient.runAll(Unknown Source) Caused by: Exception: Would be great if you already solved this and shared your solution. Thanks in advance! Best regards, Alvin
