diffusion of ions in wood
Kolavali Reddy Suresh
Hi I am very new to this COMSOL software. I have a licensed version of 4.1 installed in my computer. I need to start model the diffusion of ions in wood. Can some of you please provide suggestions on some related tutorials, so that i can start build my model? Any help is much appreciated since I have limited time to finish the task.
2 Replies Last Post 26.02.2014, 03:31 GMT-5
Posted: 1 decade ago 25.02.2014, 16:03 GMT-5
If your problem is fully saturated, just use solute transport module available in subsurface module. In the subsurface module you will find lots of inbuilt model examples.
If your problem is unsaturated, then couple the Richard's equation provision under fluid flow.
Suresh
Hi, If your problem is fully saturated, just use solute transport module available in subsurface module. In the subsurface module you will find lots of inbuilt model examples. If your problem is unsaturated, then couple the Richard's equation provision under fluid flow. Suresh
Posted: 1 decade ago 26.02.2014, 03:31 GMT-5
Thank you Suresh Seetharam, yes my problem related to fully starurated, and I will try some exmaples as you suugested.
