Syngas Combustion in a Round-Jet Burner with comsol 4.3
Julio Cesar Estrada Moreno
Hi everybody i want to reproduce the problem "Syngas Combustion in a Round-Jet Burner" with comsol 4.3, this problem has been solved with comsol 4.4, but ! I don't know how to couple reacting flow with turbulent flow, someone can help me??
2 Replies Last Post 19.02.2014, 15:06 GMT-5
Posted: 1 decade ago 25.01.2014, 08:14 GMT-5
Do you want to make is on version 4.3, not 4.3a or 4.3b? Version 4.3 doesn't include reaction rate model with Eddy Dissipation model which is needed in this model. This was introdused in version 4.3a.
If you want to do in 4.3, you will need to combine "Transport of Concentrated Species", "Turbulent flow" and "Heat transfer in fluids". Also you have to make reaction rate by Eddy Dissipation model functions.
Best regards
Tero Hietanen
Hi, Do you want to make is on version 4.3, not 4.3a or 4.3b? Version 4.3 doesn't include reaction rate model with Eddy Dissipation model which is needed in this model. This was introdused in version 4.3a. If you want to do in 4.3, you will need to combine "Transport of Concentrated Species", "Turbulent flow" and "Heat transfer in fluids". Also you have to make reaction rate by Eddy Dissipation model functions. Best regards Tero Hietanen
Posted: 1 decade ago 19.02.2014, 15:06 GMT-5
thanks Tero Hietanen!!!!!! I have some troubles coupling medels in comsol but I'm sure your contribute is going to help me!!!
