Unhelping Blog
Sorry to say but I found people here are very unhelping, even though they have a lot of expertise but even then they don't bother to help others. Knowledge is something that should be spread, not the way many of Comsolians behave.
And I am pretty sure that this post will be removed.
3 Replies Last Post 23.12.2013, 02:41 GMT-5
Posted: 1 decade ago 21.12.2013, 12:17 GMT-5
Mahmood Farman, sorry to hear of your dismay. The blog only provides for comments, but this discussion forum is much more interactive between users. I searched through this discussion forum, and could not find many times when you have asked questions, and I could not find any where you did not receive an answer. Could you be more specific ? What question do you need an answer to ? Please be aware that all responses here are completely voluntary. If you can get things very simple, then usually the answers are easier to come by.
Posted: 1 decade ago 23.12.2013, 02:03 GMT-5
Hy Freels, I am late but I was not expecting any reply from someone. Immense thanks for sparing your time. I have been trying past many many days but any comsolian did'nt help me and it was depressing as I am stuck in an issue from the past 2 months and all in vain.
Can you please check your email at f******d@o**.**v
Here I can explain you briefly that what I am trying to do is which study I should carry out for voltage induction from a rectangular beam of magnet to a simple coil?
What I am trying is Moving Mesh, Solid Mechanics for fixing one side of beam and applying force for displacement and Magnetic Field physics. I don't know that should I use these three physics collectively or it can be doe simply. I tried moving mesh model, transformer model but could not proceed.
And when I carry out time dependent study, I cannot simulate magnetic field along with moving mesh and solid mechanics and error is still intact.
Regards and waiting for your kind response.
Hy Freels, I am late but I was not expecting any reply from someone. Immense thanks for sparing your time. I have been trying past many many days but any comsolian did'nt help me and it was depressing as I am stuck in an issue from the past 2 months and all in vain. Can you please check your email at f******d@o**.**v Here I can explain you briefly that what I am trying to do is which study I should carry out for voltage induction from a rectangular beam of magnet to a simple coil? What I am trying is Moving Mesh, Solid Mechanics for fixing one side of beam and applying force for displacement and Magnetic Field physics. I don't know that should I use these three physics collectively or it can be doe simply. I tried moving mesh model, transformer model but could not proceed. And when I carry out time dependent study, I cannot simulate magnetic field along with moving mesh and solid mechanics and error is still intact. Regards and waiting for your kind response.
Posted: 1 decade ago 23.12.2013, 02:41 GMT-5
Mahmood, I suggest that you contact COMSOL Support.
