Store Iteration Results to Prove Convergence?
Hi.
Does anyone know how I can plot the solution of a point evaluation with each iteration as it solves? I want to do this as when the number stops changing it helps prove that the solution has converged. When I solve however the data for each iteration isn't recorded.
Thanks in advance
Josh
3 Replies Last Post 12.11.2013, 05:21 GMT-5
Posted: 1 decade ago 05.11.2013, 14:00 GMT-5
It seems like what you are looking for is a probe plot. Create a Probe under Definitions. Under Results while solving in the study step you can control the plotting of probes.
Henrik
Hi, It seems like what you are looking for is a probe plot. Create a Probe under Definitions. Under Results while solving in the study step you can control the plotting of probes. Regards, Henrik
Posted: 1 decade ago 11.11.2013, 06:07 GMT-5
Thanks for your response however I still can get it to work. I've created a probe under definitions then select:
step 1: frequency domain > Results while solving > plot > probes > all.
This gives me a graph of the probe solution with just a single point. I cant seem to get the x-axis to show iteration number (as with the convergence graph) and have each iteration solution shown. Any ideas where I may be going wrong?
Josh
Thanks for your response however I still can get it to work. I've created a probe under definitions then select: step 1: frequency domain > Results while solving > plot > probes > all. This gives me a graph of the probe solution with just a single point. I cant seem to get the x-axis to show iteration number (as with the convergence graph) and have each iteration solution shown. Any ideas where I may be going wrong? Thanks Josh
Posted: 1 decade ago 12.11.2013, 05:21 GMT-5
You must also switch on the probe plot in the 'Results while solving' section in the 'Fully coupled' node in the solver sequence in order to get each iteration plotted. From the 'Stationary' level only each converged solution is plotted.
Sorry that my previous answer was incomplete.
Henrik
Hi, You must also switch on the probe plot in the 'Results while solving' section in the 'Fully coupled' node in the solver sequence in order to get each iteration plotted. From the 'Stationary' level only each converged solution is plotted. Sorry that my previous answer was incomplete. Regards, Henrik
