Is it possible to use a pulse voltage in the "Electrodeposition" module?
I'm using "Electrodeposition" module right now.
Instead of Direct-Current power supply, I want to use a pulse power supply in the simulation.
Is this possible in the "Electrodeposition" module?
4 Replies Last Post 21.10.2014, 03:36 GMT-4
Hello Mike
Posted: 10 years ago 19.10.2014, 00:10 GMT-4
I also have the problem.
Comsol can analysis the pulse voltage in the "Electrodeposition" module?
The examples just for average current and variable electrolyte concentration.
I also have the problem. Comsol can analysis the pulse voltage in the "Electrodeposition" module? The examples just for average current and variable electrolyte concentration.
Posted: 10 years ago 20.10.2014, 03:46 GMT-4
Why not? Electrode potential is up to you to define.
Posted: 10 years ago 20.10.2014, 03:54 GMT-4
How to define the electrode potential of pulse voltage?
Posted: 10 years ago 21.10.2014, 03:36 GMT-4
You can define a function of your own under 'Global Definitions'. If you want a train of pulses, you can use sin function with sign function, like
sign(sin(2pi*t/T))
where T is you pulse period. You can modify that according to your need.
Lasse
[QUOTE] How to define the electrode potential of pulse voltage? [/QUOTE] You can define a function of your own under 'Global Definitions'. If you want a train of pulses, you can use sin function with sign function, like sign(sin(2pi*t/T)) where T is you pulse period. You can modify that according to your need. Lasse
