Modeling nanoparticle heating
How do i model multisource nanoparticles heating in COMSOL.
6 Replies Last Post 21.08.2013, 03:55 GMT-4
Posted: 1 decade ago 20.08.2013, 22:16 GMT-4
Hi Kwabena,
I wonder if COMSOL can handle the physical problem under nano scale.
Hi Kwabena, I wonder if COMSOL can handle the physical problem under nano scale.
Posted: 1 decade ago 20.08.2013, 22:24 GMT-4
So how do I add a weak form of the heat transfer equation to heat transfer model?
Posted: 1 decade ago 20.08.2013, 22:27 GMT-4
Maybe a more realistic question is how to model a multisource heat transfer problem in comsol.
Posted: 1 decade ago 20.08.2013, 23:41 GMT-4
Hi Kwabena,
Can you explain what is the multisource heat transfer problem?
Hi Kwabena, Can you explain what is the multisource heat transfer problem?
Posted: 1 decade ago 20.08.2013, 23:58 GMT-4
Say you want to solve the heat transfer in a domain with multiple point heat sources such that the heat generation term should be an algebraic sum of all the point sources.
Thank you.
Say you want to solve the heat transfer in a domain with multiple point heat sources such that the heat generation term should be an algebraic sum of all the point sources. Thank you.
Posted: 1 decade ago 21.08.2013, 03:55 GMT-4
Hi Kwabena,
How large is the region with multiple point heat sources?
I don't know if COMSOL can handle the problem with seperate point heat sources.
Hi Kwabena, How large is the region with multiple point heat sources? I don't know if COMSOL can handle the problem with seperate point heat sources.
