Heat Transfer in a Furnace
Hello. If I want to model heat transfer in an object inside a furnace that is heating up according to a time-dependent temperature function, what is the best way to simulate the heating conditions? Do I simply create a boundary around the object being heated and assign the temperature of that boundary to the function that describes the temperature, or is there another way? It seems that the way mentioned above will not accurately model the circumstances because now there is a layer of air separating the heated boundary and the object, and I would like to have the environment right next to the surface of the object follow the temperature curve instead. I am working in a 2D model, FYI.
Thanks!
1 Reply Last Post 16.10.2013, 08:51 GMT-4
Hello Joshua Fan
Posted: 1 decade ago 16.10.2013, 08:51 GMT-4
Hello. I have the same issue with you.
I agree with your assumption, since it is a complicated procedure in the furnace, which includes radiation, heat convection and conduction in the air, and heat conduction in the sample.
How do you set up the time dependent temperature in the boundary condition?
Hello. I have the same issue with you. I agree with your assumption, since it is a complicated procedure in the furnace, which includes radiation, heat convection and conduction in the air, and heat conduction in the sample. How do you set up the time dependent temperature in the boundary condition? Thanks
