Subdomain integration for effecive area calculation in PCF
I am doing a project based on parametric analysis of Photonic crystal fiber. For calculating effective area, I selected the option subdomain integration. I have given Ex*conj(Ex) to calculate numerator and (Ex*conj(Ex))^2 for denominator.
My doubt is in effective area equation for numerator one square term is there.
Is it need to square the value again in numarator?
For more clarification please go through the attachment..
Thanks in advance...
Jais John
2 Replies Last Post 09.03.2014, 09:10 GMT-4
Posted: 1 decade ago 15.03.2010, 11:09 GMT-4
from the dimensions here I believe you should respect the formula, no ?
if E is in [V/m] then ¦E¦^2 is (V/m)^2, now dx and dy are both in [m] (note current version 3.5a of Comsol tends to forget this in their integration variables) so your numerator is simply of units V^4
while the denominator is (V/m)^4*m^2 = V^4/m^2, which gives, once divided one by the other a unit of [m^2] for an area, and that is what I would expect, ... no ?
But this does still not necessarily mean that the formula is correct for what you are looking for ...
Hope this helps
Hi from the dimensions here I believe you should respect the formula, no ? if E is in [V/m] then ¦E¦^2 is (V/m)^2, now dx and dy are both in [m] (note current version 3.5a of Comsol tends to forget this in their integration variables) so your numerator is simply of units V^4 while the denominator is (V/m)^4*m^2 = V^4/m^2, which gives, once divided one by the other a unit of [m^2] for an area, and that is what I would expect, ... no ? But this does still not necessarily mean that the formula is correct for what you are looking for ... Hope this helps Ivar
Polepalli Siva Krishna
Posted: 1 decade ago 09.03.2014, 09:10 GMT-4
Hello sir,
i have to do surface integration of two outputs , which are having the same geometry and mesh
plese see my attachment
Hello sir, i have to do surface integration of two outputs , which are having the same geometry and mesh plese see my attachment
