Heat Transfer through 2 physics / Coupling 2 physics
Posted 13.06.2013, 11:13 GMT-4 Heat Transfer & Phase Change, Materials, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.3a 0 Replies
Im trying to figure out how to couple the modules "Heat Transfer in Solids" and "Heat Transfer in Porous Media".
I made a simple example. Two blocks on top of each other. On Block has a heat source on the bottom.
One block is a solid, the other one a porous media. How can I couple/connect them so the heat goes through both blocks?
You can find my model in the attachment.
I tried to use pairs in combination with the Continuity feature, but failed.
Any help is appreciated. Thanks.
Christian
Hello Christian Beck
