Direction of current in coil.
Hi.
I try in 2D coil change direction of magnetic flux.
I change sign of current in coil.
But nothing happend.
How can I change direction of magnetic flux in 2D coil?
Thank.
By.
4 Replies Last Post 09.06.2013, 10:49 GMT-4
Posted: 1 decade ago 09.06.2013, 06:43 GMT-4
Marian,
which method or expression are you using to calculate the flux?
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Marian, which method or expression are you using to calculate the flux? Cheers Edgar -- Edgar J. Kaiser http://www.emphys.com
Posted: 1 decade ago 09.06.2013, 07:36 GMT-4
I use surface arrows .
Posted: 1 decade ago 09.06.2013, 10:01 GMT-4
I meant how you calculate the flux value?
Edgar J. Kaiser
www.emphys.com
I meant how you calculate the flux value? -- Edgar J. Kaiser http://www.emphys.com
Posted: 1 decade ago 09.06.2013, 10:49 GMT-4
There is not problem in flux value.
There is problem in direction of magnetic field in 2D.
S N or N S
There is not problem in flux value. There is problem in direction of magnetic field in 2D. S N or N S
