Pleasse help me.
Good day.
Would somebody be so kind as to send me a model ID 14191?
Thank veri much.
goodbye
5 Replies Last Post 06.06.2017, 13:01 GMT-4
Michele Antonio Iannuzzi
Posted: 1 decade ago 10.05.2013, 04:49 GMT-4
I do need It too...have You found that in this model It is possible to change parameters when something happens? Are You interested in It?
Posted: 8 years ago 02.08.2016, 09:57 GMT-4
Hello!
Did anyone contact you with the app?? I need it too! I hear that you can use events for simulations when something changes! Is it true? I would be very thankful if someone could send me this :)
Hello! Did anyone contact you with the app?? I need it too! I hear that you can use events for simulations when something changes! Is it true? I would be very thankful if someone could send me this :)
Walter Frei COMSOL Employee
Posted: 8 years ago 02.08.2016, 10:33 GMT-4
This question seems to be with regards to the handling of events in transient simulations. The example being referred to here ( model ID 14191) is a bit out-of-date and we would instead suggest that you use the following resources to learn how to use the Events interface:
www.comsol.com/blogs/modeling-a-periodic-heat-load/
www.comsol.com/blogs/implementing-a-thermostat-with-the-events-interface/
www.comsol.com/blogs/how-to-implement-a-delay-in-your-thermostat-simulation/
www.comsol.com/blogs/control-current-and-voltage-sources-with-the-acdc-module/
Best Regards,
Hello, This question seems to be with regards to the handling of events in transient simulations. The example being referred to here ( model ID 14191) is a bit out-of-date and we would instead suggest that you use the following resources to learn how to use the Events interface: https://www.comsol.com/blogs/modeling-a-periodic-heat-load/ https://www.comsol.com/blogs/implementing-a-thermostat-with-the-events-interface/ https://www.comsol.com/blogs/how-to-implement-a-delay-in-your-thermostat-simulation/ https://www.comsol.com/blogs/control-current-and-voltage-sources-with-the-acdc-module/ Best Regards,
Posted: 7 years ago 06.06.2017, 12:15 GMT-4
Hi I was wondering if you could help me with a problem I am having that sounds similar to this. I am trying to change my initial parameters when a certain criteria is met in solving. I am looking at oxygen concentrations in three different regions of a model each which contain a number of living cells that have been defined in the parameters. If the oxygen concentration falls to a certain level say 2% I want the cells to start dying and the parameters to be updated during the solution. Do you have any idea how to do this? Thanks
Posted: 7 years ago 06.06.2017, 13:01 GMT-4
For updating the parameters during the solution use the module "d/dt Global ODEs and DAEs (ge)" and for testing condition use if()
good luck
For updating the parameters during the solution use the module "d/dt Global ODEs and DAEs (ge)" and for testing condition use if() good luck
