Part of the model is permently marked blue
Hi, i got some solving problems and actually im trying to fix the problem. It is strange that a part of my model is permently marked blue after meshing. What could this be?
Thanks!
1 Reply Last Post 23.04.2013, 06:05 GMT-4
Posted: 1 decade ago 23.04.2013, 06:05 GMT-4
the blue means that there is somewhere an active selection that has remained, you can either click outside of your model or try a CNTR-D (unselect all, opposite to CNTRL A select all)
another possible reason is that some material changes the colour of the domains, i.e. water turn the domain blue, not to mix up with "selection blue"
Hi the blue means that there is somewhere an active selection that has remained, you can either click outside of your model or try a CNTR-D (unselect all, opposite to CNTRL A select all) another possible reason is that some material changes the colour of the domains, i.e. water turn the domain blue, not to mix up with "selection blue" -- Good luck Ivar
