Typical fluid-structure interaction model
I am new and struggling to start a simple model.
I have been playing with blood vessel model from the model library.
I would like to look at the vascular behavior when blood vessel is impacted by a piston.
It is going to be dynamic analysis and I want control the velocity of piston and depth of impact.
My question is that how I can make piston move with certain velocity and control the displacement of piston.
And also how can I solve the problem with dynamic analysis?
Any help will be appreciated.
2 Replies Last Post 12.04.2013, 12:24 GMT-4
Posted: 1 decade ago 12.04.2013, 03:46 GMT-4
but arent velocity and displacement linked ?
for me s=s0+v0*t where s0 is the initial position and v0 the (assumed here constant) velocity
so try to define an imposed displacement as
s0[m]+v0[m/s]*t
with i.e s0 and v0 defined as parameters
Hi but arent velocity and displacement linked ? for me s=s0+v0*t where s0 is the initial position and v0 the (assumed here constant) velocity so try to define an imposed displacement as s0[m]+v0[m/s]*t with i.e s0 and v0 defined as parameters -- Good luck Ivar
Posted: 1 decade ago 12.04.2013, 12:24 GMT-4
The piston moves 1mm of displacement with 7m/s of velocity.
Ivar The piston moves 1mm of displacement with 7m/s of velocity.
