[SOLVED] "Solution not initialized" when using Livelink for Matlab
(Documenting for others' possible benefit.)
This error happened:
Error using com.comsol.model.impl.SolverSequenceImpl/getPVals
Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: Solution not initialized
Stack trace:
at com.comsol.model.internal.impl.SolverSequenceImpl.ax(Unknown Source)
at com.comsol.model.internal.impl.SolverSequenceImpl.U(Unknown Source)
at com.comsol.model.internal.impl.SolverSequenceImpl.getPVals(Unknown
Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.comsol.clientserver.impl.JobImpl.run(Unknown Source)
at com.comsol.server.internal.b.a(Unknown Source)
at com.comsol.server.internal.b$a.a(Unknown Source)
at com.comsol.server.internal.b$a$a.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
at com.comsol.model.clientserver.ClientManagerImpl.a(Unknown Source)
at com.comsol.model.clientserver.ClientManagerImpl.runServerJob(Unknown
Source)
Source)
at com.comsol.model.impl.SolverSequenceImpl.getPVals(Unknown Source)
Caused by: Exception:
Source)
Error in C:\Programs\COMSOL43a\mli\mphsolinfo.p>mphsolinfo (line 102)
Error in process_hexes2D_v2/process_one (line 63)
info = mphsolinfo(m, 'dataset', 'dset2');
Error in process_hexes2D_v2 (line 30)
process_one(m);
By saving as Java (after "Reset History") and comparing (gvimdiff) against an earlier version, I found that the following lines mentioning "sol2" appeared in the Java source:
model.batch("p1").feature("so1").set("psol", "sol2");
model.sol().create("sol2");
model.sol("sol2").study("std1");
Removing them, deleting the .run() calls and compiling as usual, everything worked normally.
The moral of the story is that if you create a solution, you'll be hit with a "Solution not initialized" error.
2 Replies Last Post 08.04.2013, 23:06 GMT-4
Posted: 1 decade ago 05.04.2013, 01:50 GMT-4
I would rather say, if you add a solution, tweak it, then change your physics such that the solver should be updated, you might get a solver issue, as COMSOL has recorded that you have changed it's default settings, so it does not want to clear all and reset to default.
This is a reasonable approach, up to us to say hey this implies solver changes and do them, once started, or to generate a new solver default sequence, set it active and solve again
Hi I would rather say, if you add a solution, tweak it, then change your physics such that the solver should be updated, you might get a solver issue, as COMSOL has recorded that you have changed it's default settings, so it does not want to clear all and reset to default. This is a reasonable approach, up to us to say hey this implies solver changes and do them, once started, or to generate a new solver default sequence, set it active and solve again -- Good luck Ivar
Posted: 1 decade ago 08.04.2013, 23:06 GMT-4
I forgot to mention that *all* I did was:
1. Run the simulation.
2. Right-click on "Solver configurations" and "Clear solutions".
3. Run the simulation.
4. Save the MPH file.
5. Try to access the results via Livelink for Matlab.
And it gives me the error as described above.
The solution I've provided allows one to take the existing simulation and make it accessible via Livelink again. It does mean that the simulation has to be re-run. But that's not as much human effort as rebuilding it from scratch — in a case such as mine, the only way to get useful access to the results is via mphinterp in Livelink (I need to sample points over a non-trivial boundary which would be prohibitively difficult to specify without a programming language).
I find that the "Model Builder" tree paradigm is very well suited for working with geometry, mesh sequences, physics interfaces, and plots, but it's not quite right for solvers and datasets. Parametric sweeps, adaptive mesh refinement steps, etc. are not always just sequences and trees, so it's no surprise that they lead to a mess when being represented using a tree.
I forgot to mention that *all* I did was: 1. Run the simulation. 2. Right-click on "Solver configurations" and "Clear solutions". 3. Run the simulation. 4. Save the MPH file. 5. Try to access the results via Livelink for Matlab. And it gives me the error as described above. The solution I've provided allows one to take the existing simulation and make it accessible via Livelink again. It does mean that the simulation has to be re-run. But that's not as much human effort as rebuilding it from scratch — in a case such as mine, the only way to get useful access to the results is via mphinterp in Livelink (I need to sample points over a non-trivial boundary which would be prohibitively difficult to specify without a programming language). I find that the "Model Builder" tree paradigm is very well suited for working with geometry, mesh sequences, physics interfaces, and plots, but it's not quite right for solvers and datasets. Parametric sweeps, adaptive mesh refinement steps, etc. are not always just sequences and trees, so it's no surprise that they lead to a mess when being represented using a tree.
