pump (FSI)
Hello everybody ( Comsol)
I'm trying to modeling pump with 03 actuators mechanical using MEMS FSI model. The figure (diagramabomba) shows the design of a pump flow controlled by 03 actuators. The actuators apply a force (F1, F2, F3) on the membrane, causing the displacement of the membrane to the wall. This is repeated in a cycle of operation.
I do not know how to interact with the modules in Comsol (Incompressible Navier-Stokes, Plane-Strain, Moving Mesh).
Can someone help ?
2 Replies Last Post 21.10.2011, 09:40 GMT-4
Hello Arlindo Garcia
Posted: 1 decade ago 20.10.2011, 20:15 GMT-4
I have a similar problem, have you been able to resolve this issue?
Hi, I have a similar problem, have you been able to resolve this issue?
Posted: 1 decade ago 21.10.2011, 09:40 GMT-4
Check out the Peristaltic Pump model #985 in the COMSOL model gallery. It shows how to efficiently set up such FSI problems with structures, fluid flow and a moving mesh. I used that example as a starting point for setting up a more complex 3D pump model (see, www.veryst.com/peristalticpump.html).
Nagi Elabbasi
Veryst Engineering
Check out the Peristaltic Pump model #985 in the COMSOL model gallery. It shows how to efficiently set up such FSI problems with structures, fluid flow and a moving mesh. I used that example as a starting point for setting up a more complex 3D pump model (see, http://www.veryst.com/peristalticpump.html). Nagi Elabbasi Veryst Engineering
