Hello Debadrita Paria
23.09.2014, 23:11 GMT-4
Please try the direct solver instead of the iterative solver. I had exactly the same problem (extremely slow convergence at about 360 nm for a silver nanocrystal), and the direct solver worked perfectly.
8 years ago
20.01.2017, 11:10 GMT-5
I was stuck in same problem.
Thanks for your comment. !
Walter Frei
COMSOL Employee
8 years ago
20.01.2017, 11:44 GMT-5
Hello All,
Having to use a direct solver is also often a sign that you've undermeshed the problem, especially in the silver material domains.
If you're dealing with a model that has lossy materials, please read:
www.comsol.com/blogs/modeling-of-materials-in-wave-electromagnetics-problems/
www.comsol.com/blogs/simulation-tools-for-solving-wave-electromagnetics-problems/
Meshing more finely may improve solution speed when using the iterative solver (and although a more finely meshed problem will use more memory, the iterative solver uses much less memory that the direct solver, so you generally come out ahead.)
Best Regards,
Hello All,
https://www.comsol.com/blogs/modeling-of-materials-in-wave-electromagnetics-problems/
https://www.comsol.com/blogs/simulation-tools-for-solving-wave-electromagnetics-problems/
Best Regards,
